i have double checked and everything looks to be correctly assembled. this is my first attempt at anything like this but it looks good.
All i seem to be getting out is a low/low-mid oscillation. it does increase in volume when the knob cranked which makes me slightly happy it is being amplified but i can’t fathom out what is causing the noise. no signal sent to it comes through.
i understand i might be overloading the input stage.
i am wishing to build a mini amp to boost the output from an audio interface to headphones for a drummer to play to a metronome in a live or studio situation.
what kit would i need for this or can the k1803 be modified?
The K1803 is a PREamplifier! It is clearly stated that the max. input voltage is 40 mV. You are using a line output! This give several 100’s of mV’s!! Ofcourse you are overloading!
Use an AMPLIFIER kit like the K4001 or the K8066 when you find it (K8066 out of production).
