This is me first attempt at a velleman kit.
I’ve put together a k1803, powered it with a 9v battery.
This is preamp goes between an old record player that doesn’t need RIAA correction (shellac 78rpm), and a line entry on a modern amp.
I notice a lot of noise through the speakers.
If I touch the wire cable from the turntable output, there is less noise.
Trouble is there is no extra ground wire on the turntable, like on modern turntable.
I can make a new one, but where to hook it up from and to ?
Thanks for your help
