Hi,what cable is rigt to use with k8056? can you send a link to this cable?
You will have to make/modify the cable yourself, as the K8056 only accepts bare wire, there is no connector. Basically, any RS232 cable with a female 9-pin sub D at one end will do the job. K8056 manual shows pinout and hook-up info.
