Isolator Guide cooling
Hi guys,
According to several people (including Velleman) the isolator guide made of PEEK needs to be cooled to prevent melting it.
But after googling the PEEK material i saw that the melting temperature is at 343 degrees (according WikiPedia).
So why does it needs to be cooled?
I guess, that the filament itself will melt and block the tube/nozzle. so cooling the isolator, you actually cool down the part of the filament.
If I have had blocked nozzles, always the material inside the PTFE tube as melt and thicker than expected.
What is more important is that the thermistor reads the correct temperature. If it is mounted incorrectly for example, the thermistor might read 220°C, while the actual temperature is 350°C. Seemingly melting the isolator guide at “220°C”.
Even further - while PEEK may melt to a liquid at 343 degrees, like any plastic it very probably starts to soften and deform at a significantly lower temperature.
