Is VM130T is direct replacement for VM108?
Please can you confirm if the VM130T is a completely compatibly replacement for the discontinued VM108 and will work correctly with the VM109 and K8057 receiver boards without modification.
Simon
Yes, it is compatible. It is possible that the range is slightly less, due to the fact that the unit fully complies with current regulations. In most cases, no noticable range reduction will be noticed.
