Is there firmware available for K8203 +cnc milling?
I recently bought A K8200 with proxxon drill/grinder for cnc applications.
From the documentation I understand I need to upgrade the firmware to use it as CNC.
I am interested in buying a K8203 upgrade to improve the quality of the prints.
Is there firmware available that supports both the K8203 upgrade as CNC applications?
With kind regards,
Rob
Hello! Were you able to operate the machine with the amendment to CNC ?, I can`t work with this. The firmware suggested dont work (3dprint.elettronicain.it/wp-cont … ILL_ON.zip).
I haven’t tried cnc milling as yet. I was hoping that I could do a single firmware change and change both cnc option as k8203 in one go.
What is your problem? software won’t load, doesn’t print at all, or just doesn’t do the negative z movements?
did you change the printer setting to cnc in your reptier/slicer?
