Why do say that the micros should be velded to the red cable to the bord ?
The red cable is cut away
Sorry, we have troubles understanding you post, please elaborate.
Please refer to which chapter you are at in the assembly manual and which microswitch you are currently installing. Provide as much information as possible so we can also understand.
there are 3 micros, one for each axle. They shall all be connected the same with a 3 cable connector. The middle one (the red cable) shall be cut away. Then why do the instruction tell me to solder the red ? The remaning cable is orange
I would like to have an simple wiring diagram of all the cables to the controllerbord
You can use the orange wire for the “red” in the instructions.
As long as it’s the 2 outside wires.
We are still guessing where in the assembly manual you are at the moment…
For the Z-axis endstop you should get this:
why isent there a wiring diagram ?
Thankyou
