I would like to measure current and create a diagram of it, but I can’t measure current with ste standard probes.
Which current probe is compatible with the PCSU1000?
I want to measure current and voltage at the same time.
Hi
I search long time for a current probe which can be used with oscilloscope. Finally I found the probe of LabDevice.ch. It is very handy to use!
And it was very suitable for my measurements I had to do. I measured current in a range between 100uA and 10mA. They even have two probes for different current ranges.
It has as well a big bandwidth up to almost 3MHz.
