Hi.
I’m working on a new project and I would try something with thread.
When I draw it everything is oke, but when I would like to print those objects my printer just printing a round object without thread.
Hi.
What software did you use for designing the treaded parts?
Is the thread visible in the slicing preview?
If not, the file dodn’t slice correctly.
I use inventor for my designs.
This is the slicing preview. I thought that inventor was a good program for designs.
What slicing software did you use and what settings?
What are the dimensions of the threads?
[quote=“mich777”]Hi.
[/quote]
Inventor is only projecting a thread-like bitmap at your model, to save memory.
If you really want thread in your models, you should use a cut-extrude spiral with the exact thread dimensions.
Then you can slice it.
