every time i open the remote controle i need to type de ip adres, can i program a the adres without forgetting it?
Depending on your provider, your IP address may change every day, so remembering it may not be an option.
Check if your router supports DynDNS. DynDNS allows you to link a name to your IP address, for example ‘johndoe.dyndns.com’. That way the only thing you need to remember is the name. Like everything involving networks, it can be quite confusing for the average user, so try to get some help or advice from someone you know that is into computers.
