Interfacing K8061 with other kits
I have built up a working K8061, and understand the basics of what I am trying to achieve, but would like to make sure I’m not going to start blowing out boards when I actually make connections.
I’d like to control the DC dimmer kit (K8064) and Quad triac switch card (K2634). Both of these kits refer to other USB kits (8055, etc.) by name as being compatible, but not the K8061.
Please let me know if these are compatible or if I need to do additional work to make them so.
Thank you
Both the kits K8064 and K2634 are compatible with the K8061 too.
Actually K8061 is an upgrade of the K8055.
Thanks for clearing that up.
I did some searching through the forums and did find a hook-up diagram for the triac card. Is there a similar diagram for connecting the dimmer (K8064)?
It is very easy connection:
Just connect one of the analog outputs of the K8061 (e.g. DA1) to the +terminal of the connector SK3 on the K8064 card and connect GND to the -terminal of SK3.
