I had to stop my assembly efforts today when I could not get the instructions to download. The first few pictures of each chapter are downloading, but the rest of the pictures are blank. Tried reloading, rebooting, different browser, etc. I assume it will come back online eventually, but is there a mirrored site or alternative place to get the instructions if this issue persists or pops up again?
Hi T86951,
the complete assembly manual is available as pdf for “offline” use. K8200 website, support, downloads section.
Cheers,
kuraasu
In the upper right corner of each chapter there is a download button so you can download that chapter.
The PDF download links for ‘005 - ASSEMBLING THE RIGHT UPRIGHT OF THE FRAME’ - “http://www.k8200.eu/downloads/files/k8200/manual/en/en_005%20–%20ASSEMBLING%20THE%20RIGHT%20UPRIGHT%20OF%20THE%20FRAME.pdf” and ‘018 - WIRING THE Y AXIS MOTOR AND MICRO SWITCH’ - “http://www.k8200.eu/downloads/files/k8200/manual/en/en_018%20–%20WIRING%20THE%20Y%20AXIS%20MOTOR%20AND%20MICRO%20SWITCH.pdf” do not appear to work (the downloads freeze shortly after starting, possibly suggesting corrupt files). However, as has been pointed out above the complete assembly manual can be downloaded rather than these individual chapters.
Dear T86951,
Thank you for letting us know, I’m sad to let you know I’m unable to reproduce the issues you describe in your post. All the pdf’s are opening correctly.
I would suggest to clear your caches in the first place. If it still does not work, please reply here as we will look even deeper into your problem.
Hi VEL466,
Further to my earlier post reporting the failure of PDF downloads for sections 005 and 018, this appears to be specific to Internet Explorer.
I have tested from two locations in the UK and the downloads (for these sections only) freeze in Internet Explorer 9 and 11 (I have not tested other versions of Internet Explorer), however they complete successfully in both Firefox and Chrome.
