Installing and using a newer Repetier Host version?
Hi all!
Seems the Repetier software gets regular updates at
repetier.com/download-now/
Currently they are up to v1.5.6, while the Velleman-supplied Repetier-Host still is at v1.0.6.
Are there any considerations upgrading to v1.5.6? Is it a good or a bad idea? A quote from Repetier about v1.0.6: “Older versions are not supported anymore and contain unfixed bugs and should be avoided when possible.”
Are there any reasons for Velleman not releasing just as regular updates?
Thanks!
hi peh
I too am a total beginner !! and I asked myself the same question. What for ? I asked today at Raby who is an expert, I think you can see his response. if I have something I will let you new message
Sincerely
Jean Michel
You can install the newer version; you just have to transfer the config and parameters (Repetier and Cura) from the old one to the new one.
I take it Velleman can’t get a customized version from Repetier each time they’re releasing a new one.
