I have new problem, i tried solve it for two days and i don’t have any more ideas what i can do more. Problem is simple to show:
Start of printing in red circles.
At the begining of printing perimeters line is to far. Like it is visible, this occour in two axis and circles.
- When i set 2 or 4 lines for external perimeters effect is the same, first line don’t stick to the others.
- i tried different retraction speed from normal 150mm/s to speed of print 25 mm/s, the same results.
- prepared gcode using cura instead of slic3r.
- tighten short belts, normal and extremly strong.
- i add extra tensioners on long belts, nothing change.
- all pulleys are in place, no loose screws
- aligment is good, circles are perfect.
- smooth movement of printhead.
Have you some ideas what could be the cause?
