for the next firmware you might change the title of the menu. To me it looked like it would FORMAT the card (or initialise as it is called sometimes). Perhaps “load sd card” or “refresh sd” is a better description.
I completely agree (and btw, it’s easy to fix yourself, but that’s not really the issue here).
In any case, wouldn’t it be possible to make an autodetect instead? I have at least on other firmware where the manual init is not needed…
As i am now fully aware of the meaning and function,it is not necessary for me to change it any more. I was merely suggesting to change it so that new users might benefit from the inproved user experience.
That one did throw me as well
But after reading the section on “How you use the LCD” I understood
