[quote=“kuraasu”]Hi Kenny,
yes, I can reproduce the behavior you described. As said before, this happens with a certain combination of parameters. Could you post the settings section at the top of your G-code (should be lines 3 to 18)?
Cheers,
kuraasu[/quote]
Hello kuraasu,
I just deleted al config files in Slic3er and loaded them again. Now it looks like the baseplate is filled completely! I’ll try to print it again today. Here you have my config log:
[b]; generated by Slic3r 1.0.0RC2 on 2014-02-16 at 09:12:08
; layer_height = 0.25
; perimeters = 3
; top_solid_layers = 3
; bottom_solid_layers = 3
; fill_density = 0.25
; perimeter_speed = 30
; infill_speed = 50
; travel_speed = 200
; nozzle_diameter = 0.5
; filament_diameter = 3
; extrusion_multiplier = 1.1
; perimeters extrusion width = 0.42mm
; infill extrusion width = 0.42mm
; solid infill extrusion width = 0.28mm
; top infill extrusion width = 0.28mm
; first layer extrusion width = 0.33mm
[/b]
Can you see some other wrong settings I should not be using?
Edit: For some reason, printing for the first time with this setting my print came loose mid-print. It started warping and then came loose…
Edit2: I found on the velleman website this comment about the K8200-PLA-STANDARD_NEW.INI:This file is only compatible with Repetier 0.90 and Slic3r 0.9.10b.
So I checked my versions:
Repetier Host: V0.95F
Slic3r: 1.0.0RC2
So these versions do not match, is this a problem or is a newer version than given by velleman not a problem?
I really don’t get it, I’ve tried printing it 4 times already at about 70% print one of the corners comes loose and starts warping untill the complete object comes of the table… With al my other prints no problem and this simple plate gives me nothing but problems (I don’t know if it’s the object or the new settings that causes these problems). Also the edges are not printed straight up but curved. (I print with a mirror and the blue tape)
I have taken some pictures:
Here you can see the warping (picture is upside-down for some reason) as you can see now the plate is filled completly with the honeycomb structure:
Also the first layer is printed not that straight, the first line is ok but then it’s printed a bit “in the air” if you know what I mean. This caused skipping some lines (but that’s another problem):
I have no clue what I’m doing wrong
