I assembled it after many attempts , now I have a problem could you all figure this out every press of the button results in a two, four , or seven what has happen to my other numbers ?
Most likely an assembly error.
I’ve just put this working video together for you’ll to view I guess I might have to reassemble it but put the resistors in first . youtu.be/GUhBq61N_e0 see if you can spot the difference .its on a bread board .
Just rebuild the kit and follow the order stated in the manual. Breadboards are always dangerous because of their stray capacitance and bad contacts.
