Impossible d'Imprimer de petites pieces en 0,05 ou 0,1 mm
I saw ! but I couldn’t reply directly.
Yes your print is ok, did you change the flow ?
One of my friend just finished to build your printer and made this test without changing the flow value and had the same result at me(but with PLA) !
He used a filament coming from: reprapworld.com/.
We did not adjust flow.
Settings are optimized for Velleman PLA & ABS.
I bet that a lot of your customers are not buying your filament !!!
Hey, velleman can’t supply settings that work on every printer and with any filament …
of course not … but having to change the flow to 70% to make it works with other filament it’s a little bit strange !!!
And just as an example, build a rostock max an take the standard setting they are giving on theyr website, it works with every printer and every filament !
[quote=“mcbride19”]I bet that a lot of your customers are not buying your filament !!![/quote]It’s your job to calibrate your printer for your filament.
yes tha’s right but standard parameters may fit standard filament !!
yes tha’s right but standard parameters may fit standard filament !![/quote]
Probably, but there a quit a kind of manufacturing tolerances… No spool is the same…
cheers,
Christian
This would be like paint.
The color from one MFG is not going to match the color from a different MFG.
Sometimes the same 2 colors from the same MFG do not match.
Velleman can get it close but it is your job to dial it in.
So if I understand well, seemecnc made standard parameters that fit a large number of different filament(I mean coming from different sellers) and Velleman(that is a bigger society) does not !
I don’t want to blame Velleman, it’s just that I found curious that a smaller society(as seemecnc or solidoodle) can be able to made more “finished” standard parameters than a bigger society …
And i’m not going to talk about the fact that the software package only works on windows and not on mac OSX … but there is a lot of 3d printer users on MAC.
Bonjour à tous,
Pour ma part, je suis satisfait de la K8400
Il se peux aussi que je ne sois pas aussi exigent que vous autres :slight_smile:
Toutefois, mon problème ce situe au niveau de la position du plateau.
Il me semblerait logique que le plateau aille en position bas (la plus bas possible) sur Z après un impression.
Mais cela n’est pas le cas chez moi !?
Je voulais savoir comment vous faites pour récupérer vos pièces ?
Est-ce que vous enlever le plateau ? et si oui comment procédez vous ?
Merci de votre réponse
Romuald
C’est juste une ligne de gcode à rajouter pour amener le plateau a la position voulue(fin de course en bas) juste aprés impression.
C’est dans la section configuration de cura dans repetier, à l’onglet gcode et section gcode de fin.
Perso je ne l’utilise pas . Mais ça devrait donner un truc comme ça :
G90 ------> position absolue (je ne suis pas sur de cette ligne pour cette imprimante là)
G1 Zxxx ------> position voulue(xxx représente le nombre à entrer pour donner la position que l’on veut atteindre)
Le code est à mettre dans le END G-code : 1ère ligne
G90 ; position absolue
G1 X0 Y0 Z190 (met l’extrudeur dans le coin avant gauche et le plateau en bas)
ce qui confirme ce que je disais , a noter qu’il n’est nullement nécessaire de remettre les têtes en position de départ puisqu’elles sont obligatoirement ramener à cette position au démarrage d’une impression.
Un grand merci à vous :slight_smile: pour cette info.
Il s’agit de m’a première “imprante3D”.
Je suis novice dans ce domaine.
Mais pour le moment, je me débrouille plutôt bien.
Enfin, j’obtiens ce que je veux.
Je fais bien sur quelques essais avant d’obtenir le bon résultat, mais c’est satisfaisant.
encore merci
Romuald
