IMPORTANT: Upgrade your Vertex to firmware 1.4
New firmware version 1.4 for the Vertex 3D printer
Updated firmware 1.4 has been released for the Vertex 3D Printer. This firmware addresses a critical issue of uncontrolled nozzle heating while in the “load filament menu” as well as in the “show firmware” menu. Users are advised to perform this upgrade to avoid any issues. This new firmware also adds LED control via the LCD panel or via Gcode to drive the K8403 LED add-on.
The firmware files can be found on the download page of the Vertex 3D Printer:
vertex3dprinter.eu/support/downloads
You can update the firmware on your printer using the instructions on the manuals page.
When you have uploaded the newer version of the firmware you must not forget to reload the EEPROM settings. This will update the stored values on the printer as these are not updated via the Arduino upload process. Go to the SETTINGS menu, then scroll down until you see RESTORE FAILSAFE, access this menu and the firmware will load the new values into the EEPROM, next choose the STORE MEMORY menu (also in the SETTINGS menu) to store the new values. DO NOT FORGET THIS STEP!!
Hi
After updating the firmware 1.4 I can no longer print only on my 2nd extruder. In the Repetier 1.6.2. is Extruder 2 selected. On the printer the temperature is read from the 2 extruders. When viewing the firmware on the printer it tells firmware 1.4 and 2 heads read.
Thanks a lot.
Hi
Please add some improvements:
After printing:
-The fan of the extroders let it turn until the temperature has dropped.
-Pulling the filament back until there is no more tension
This is to prevent the filament from thickening in the printer-head. At the start of a new printing jop, the problem is hiding the filament in the printer-head
When printing:
-Give us the possibility to print back with only the second extruder
thanks Bart
Just wanted to print. Have it turn off. The temperature remained at 147 °c but after the a reset, the temperature had already gone through to + 400 °c!!! Take your responsibility and solve the problems. Plaece!!!
this is the error I get if I check the firware
Arduino: 1.8.3 (Windows 10), Board:“Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)”
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries G:\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10803 -build-path C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698 -warnings=none -build-cache C:\Users\dirkg\AppData\Local\Temp\arduino_cache_690712 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose G:\3D printer K8400 firmware\Vertex-Firmware-H1-master (1)\Vertex-Firmware-H1-master\vertex-m1-v1.4-h1\Marlin\Marlin.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries G:\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10803 -build-path C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698 -warnings=none -build-cache C:\Users\dirkg\AppData\Local\Temp\arduino_cache_690712 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose G:\3D printer K8400 firmware\Vertex-Firmware-H1-master (1)\Vertex-Firmware-H1-master\vertex-m1-v1.4-h1\Marlin\Marlin.ino
Using board ‘mega’ from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core ‘arduino’ from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\Marlin.ino.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\Marlin.ino.cpp” -o “nul”
Using cached library dependencies for file: C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\BlinkM.cpp
Using cached library dependencies for file: C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\ConfigurationStore.cpp
Using cached library dependencies for file: C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\LiquidCrystalRus.cpp
Using cached library dependencies for file: C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\MarlinSerial.cpp
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\Marlin_main.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\Sd2Card.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\SdBaseFile.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\SdFatUtil.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\SdFile.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\SdVolume.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\Servo.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\cardreader.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\digipot_mcp4451.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\motion_control.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\planner.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\qr_solve.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\stepper.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\temperature.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\ultralcd.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\vector_3.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\watchdog.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src\LiquidCrystal.cpp” -o “nul”
Generating function prototypes…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\Marlin.ino.cpp” -o “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\preproc\ctags_target_for_gcc_minus_e.cpp”
“C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags” -u --language-force=c++ -f - --c+±kinds=svpf --fields=KSTtzns --line-directives “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\preproc\ctags_target_for_gcc_minus_e.cpp”
Bezig met het compileren van de schets…
Vorige gecompileerde bestand C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\BlinkM.cpp.o wordt gebruikt.
Vorige gecompileerde bestand C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\ConfigurationStore.cpp.o wordt gebruikt.
Vorige gecompileerde bestand C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\LiquidCrystalRus.cpp.o wordt gebruikt.
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\Marlin.ino.cpp” -o “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\Marlin.ino.cpp.o”
Vorige gecompileerde bestand C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\MarlinSerial.cpp.o wordt gebruikt.
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\Marlin_main.cpp” -o “C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\Marlin_main.cpp.o”
In file included from C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\SdFile.h:27:0,
             from C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\cardreader.h:8,
             from C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\Marlin_main.cpp:44:
SdBaseFile.h:38: error: using typedef-name ‘fpos_t’ after ‘struct’
struct fpos_t {
In file included from C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\Marlin.h:10:0,
             from C:\Users\dirkg\AppData\Local\Temp\arduino_build_209698\sketch\Marlin_main.cpp:30:
c:\program files (x86)\arduino\hardware\tools\avr\avr\include\stdio.h:950:33: note: ‘fpos_t’ has a previous declaration here
extension typedef long long fpos_t;
Bibliotheek LiquidCrystal op versie 1.0.5 in map: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal wordt gebruikt
exit status 1
I wa
You should try Arduino 1.0.6 or lower.
You can download it from this link
https://www.arduino.cc/en/Main/OldSoftwareReleases#previous
