Ignition kit K2543
I put together the K2543 ignition kit, and I would like to install it on my Yamaha FS-1 moped. The 6V parts have been altered.
I also have the recommended enclosure G304.
This box is totally closed, while the ignition-manual says the coolingplate needs to be “in the air”.
I’m afraid the whole thing will overheat in the box & in my moped’s frame.
Can I assemble it this way, or is it better without the box ?
Please your advise !
Peter.
You can use the recommended box, however, you should put the heatsink on the outside of the box…
