Ideal settings Repetier Host for PLA
Are there ideal settings to set in Repetier Host for Velleman PLA? I mean temperature, extrusion length,…
I printed a little cube (20x20mm) and the top and bottom are not completely, let’s say, waterproof.
I’m planning on printing a vase, so I want to be sure the vase is watersealed
[quote=“fl1p”]Are there ideal settings to set in Repetier Host for Velleman PLA? I mean temperature, extrusion length,…
I’m planning on printing a vase, so I want to be sure the vase is watersealed[/quote]
I recommend ~210°C temperature for PLA. Just add extra layers of full print in Slic3r at the bottom to make sure the bottom is waterproof and increase the first layerheight.
I print at 190 4mm retraction 110mm retraction speed.
Make sure the Z axis is properly calibrated.
