hello,
i am trying to use a K8000 card, with a VB program, that i can call upon from an GW-BASIC apllication.
but even in CMD this command sometimes works, and sometimes (as in 3 seconds later) not.
i get a popup saying “this is the I/O routine for the K8000 card. This is not a stand-alone program”
tests made on 2 XP machines, with same result.
i get display that it is processed ok, see below,
and on the card the leds LD17 and LD18 flash on, but no outputs are turned on.
C:\K8000>K8000out.exe on1 on3 on5 on7 on9 on11 on13 on15
K8000 Interface application
Processing port (1) - ON (chipNo:0 ,ioChannel:1)… [done]
Processing port (3) - ON (chipNo:0 ,ioChannel:3)… [done]
Processing port (5) - ON (chipNo:1 ,ioChannel:5)… [done]
Processing port (7) - ON (chipNo:1 ,ioChannel:7)… [done]
Processing port (9) - ON (chipNo:1 ,ioChannel:9)… [done]
Processing port (11) - ON (chipNo:1 ,ioChannel:11)… [done]
Processing port (13) - ON (chipNo:2 ,ioChannel:13)… [done]
Processing port (15) - ON (chipNo:2 ,ioChannel:15)… [done]
diagnostic test K8000 program works fine.
K8D.dll and K8E.exe are in the same folder then the K8000out.exe that was made for me , and in the \windows\system32 folder.
all i need is a to be able to shell a command and say “k8000out.exe on1 on 15”
what is wrong ?
Thanks in Advance,
Anthony
