I need more output power on PCGU1000. Is there a possibility to amplify the output signal.
Is there a possibility to use two or more PCGU1000 on one PC to get more power ?
I need the whole frequency range.
Sorry, running more than one generator is not possible.
I suggest an external amplifier.
If you increase the internal amplifier gain by changing a resistor value inside the generator, then the warranty is void.
[quote=“VEL255”]Sorry, running more than one generator is not possible.
If you increase the internal amplifier gain by changing a resistor value inside the generator, then the warranty is void.[/quote]
I was looking for an amplifier which works for the whole frequency range. But I have not found any. Which one do you suggest ? Or does Velleman produce such a device ? It should also not be to expensive !
I also didn’t find amplifier for it but i am building my own(OPA541 based) for lower frequencies(1mHZ…20KHz). There is also amplifier chips like OPA551/OPA552 what can be used over 1MHz and drive ±200mA/±30V.
Maybe this helps.
