Hi!!
Can i download the cd from somewhere ??
/Jamppi
Hi!!
/Jamppi
You can download PCLab2000SE here:
http://www.velleman.eu/downloads/files/downloads/pclab2000se_v4_05_setup.zip
I have the same problem , please can someone give me the good driver for PCS100 i installed Windows XP just for PCS100 but i have a broken cd too !
THANKS
By the way the link don’t work VEL417 …
The link has been edited to point to the latest version, please try again
thanks for the link
Excuse me i have a question , when i connect my oscilloscope i have a message who ask me to locate the driver for hardware , where is PCS100 driver located please ??
Thanks a lot
I don’t think there is a driver for the PCS100.
You will need to have a native parallel port in your machine.
USB to LPT port adapters will not work with this unit.
I have a Parallel adapter card its not an USB to LPT port adapter , this card don’t have any problem , i mean i see it in device manager (LPT3 port) , so why i have a message asking for a driver ?
[quote]so why i have a message asking for a driver ?[/quote]If your operating system is 64 bit, then you get this message and you can’t use the PCS100 with this operating system. For more info please see: viewtopic.php?f=10&t=14766
If your operating system is 32 bit, then the the possible solution can be found here:
viewtopic.php?f=10&t=10119
it finally work , thanks a lot
