I cant see the result on REPETIER-HOST V1.06
For some days when I slice an object, I cant see the result, but the *.gco seems correct.
What happens with REPETIER-HOST V1.06 ?
Should I re-install it or what?
thanks.
Henrig
At the top of the screen there should be a button that says “Hide Filament” with a line through the icon.
If you click it it will say “Show Filament” and the line will go away and the sliced object should appear.
AH AH, thank lot, now I see it.
I’m a real beginner, you can imagine it.
I work to adjust the temperature With: http://www.thingiverse.com/thing:1548697
I dont know the GCODE.
Is M104 S2XX or M109 S2XX to change it ,
Anyway, thanks for your help
Henri
If you are new to the Vertex (K8400) you should make the following changes to the Cura slicer.
With Repetier open click on the slicer tab then click on the Configuration button.
Now in the left panel there will be 5 tabs click on the “Extrusion” tab
Change “Retraction Speed” to 110mm
Change “Retraction Distance” to 4mm
Just under where it say CuraEngine Settings click on the Filament tab
If you are printing with PLA change the “Print Temperature” to 190C
Make sure you click on the “Save” button.
I think the command you want is M104 SXXX
But someone else will need to confirm that.
Thanks for advice, I will use it to the next edition.
Henri
