Hello ! I have trouble with ps1205rp charger, from my HPS50. Output is 3.67V. I try to change resistor responsible with voltage regulation and the voltage is in range 1.3V to 6V . I can’t read IC code. Can you send me a schematic ?
Sorry for my English
Thanks, Horia
Hereby a link to the technical doc for the HPS50. Please allow 1h for server update. http://www.velleman.eu/images/tmp/HPS50%20technical%20doc%20V2.pdf The charger itself is not servicable.
Thanks for schematic. I found an resistor with value changed. now is working correctly. Thank you.
