I have searched the forum and so far not found any resolution. Using a HPS50 saving data to memory, connecting with OEM USB I select the Com port, yet I can’t get the data to diplay on PC.
HPS50 Capture software Rev. 3.3 Windows XP Pro. Cheers, Bob
If no trace is appearing, then your HPS50 is probably not sending out any data.
So I should have said that I have already tried this, but I tried it again and I never see anything on the software screen.
Resolution: I have uninstalled and reinstalled rev 3.3 software and this fixed the issue.
Happy to read you were able to fix the problem.
