I have an old Velleman HPS5 which I used to use in college very happily. However, I found it, replaced the old batteries with brand new duracells and it won’t respond. Batteries measure fine at 1.6V each. Tried the reset button. Nothing.
Electronics don’t go bad overnight.
There must be a cause, most likely a mechanical cause such a bad or loose contact, broken wire, batteries that do not fit the battery holder or that do not touch the battery springs etc…
However, if you cannot get it to work, you can still return the unit for inspection/repair.
Okay thanks. I can’t see anything wrong with it. Its little fuse shows 0 ohms resistance. The voltage coming in from the battery pack shows 8.1V or so. I don’t see any cracks or loose wires. Sigh. But since you’re in the EU, it’ll probably be absurd to try to send it in.
Hi I live in Australia and have the same model unit with the same problem. I’ve tried battery and DC power supply with absolutely no response from the unit. Is there somewhere I can have it sent/take it for repair??
