Hello
I am using an HPS40 scope (age unknown). It has recently developed a problem.
It will work fine for a few minutes after inserting the batteries. Then, the signal vanishes from the screen. Pressing auto lets it range out to 20V/Div and it appears to be showing a steady 60V signal.
Grounding the probe, or even removing it, makes no difference.
Also, the left arrow key is mostly unresponsive - it does work eventually, but takes some prodding to get it to work.
Are these repairable faults?
If so, is it likely to be economically sensible to repair? (I can replace the unit with an equivalent PC scope for around £150)
Regards
Steve Peake
McMurtry Ltd.
