Hello to all
Is that someone had this failure:
For the light I must draw the battery and reset and lp oscillator failed mesage appears.
Hello to all
Either the LP oscillator is defective or there is a mechanical problem which causes an interruption/bad contact around the oscillator.
As you know how to enter the service menu, this means that you have the service manual, so you have the diagram.
If you are unable to solve the problem, you can return the unit for inspection/repair to:
Velleman Projects Tech. Dept.
Legen Heirweg 33
9890 Gavere
Belgium
US residents: please call (817) 284 77 85 for RMA#
