Hi, I’m posting this as I’ve had no response to an email sent earlier this week.
I recently purchased a Velleman HPS141 Component Tester to use with a recently purchased HPS140mk2 from CPC in the UK.
I’ve only used the HPS141 for a few hours over a number of days and in this time the very fine cables linking two of the probe test clips have snapped off. I have been very careful in handling the unit as these looked fragile, but these have sheared off with very little force (just the twisting/movement in using the unit). It appears that the wires are soldered in place but not mechanicallty secured in any way and so the cable just rubs against a sharp metal edge inside the clip.
I was considering returning the product to the supplier for a refund but it doesn’t really help me as I really like the product otherwise and would like to continue using it. Apart from the above mentioned issue, I wanted to say that it is a very good and high quality product and works well with the HPS140mk2.
I could try and replace the clips myself but I fear the same problem will just re-occur and I don’t feel that I should need to do this. It seems a real shame that the product is let down by these issues and I wondered if anything could be done (i.e. is this available with alternative more robust test leads/probe tips)?
I would be very grateful for any help you can provide.
Kind regards
