I have just purchased a new HPS140 from Maplin Electronics(UK) and placed it on charge using the supplied USB charger lead.
After an hour of charging there was a noticeable smell of ‘hot electronics’ from the top of the HPS140 but its case was not noticeably hot. I decided to measure the off load output voltage of the supplied USB charging lead. The output voltage was 9.91V. 10% high… Not very good for a charger specified as 9V.
I then charged the HPS10 using a high quality regulated 9V mains plug pack and the ‘hot electronics’ smell from the HPS140 was much reduced. It may just be the smell of the charge regulator getting hot on a new PCB ?
Please will you advise me of the acceptable and safe input voltage range for the HPS140 charge socket and is the supplied USB charge lead supposed to produce almost 10V ?
Fraser
