HPS140 Low battery warning
Hello there, I have just started using the HSP140 and am finding it better as I learn how to use it more, but one thing I would like to know is if there is a low battery warning display on the unit?
The HPS140 is not equipped with a low battery warning.
OK, thank you for the reply
Interesting…
As a new owner (very impressed) - what happens when the battery is exhausted? Auto-switch off? Display failure? Measurement inaccuracies? ***
No doubt I will find out…
*** EDIT #1: I read that the backlight dims first, then the display goes wonky…
And whilst we are on the subject, I presume the CHARGING red LED doesn’t extinguish when fully charged. Or does it?
EDIT #2 - from VEL417 elsewhere…“No, it never turns off. Charge current is limited so that it can safely charge continuously.
