I purchased a HPS10 to do some testing on crankshaft sensor so I can see rising and fall edge on a mag sensor. I am looking for a rising and falling wave form however I cannot get it configured correctly.
This is what I get,
This is what I need,
I understand the bottom one is a two channel but the signal is what I am looking for. Any and all help or suggestions are welcome and appreciated!
The signal that you want to display appears to be within the specs of the HPS10, so at this time we have no clue why it does not display correctly.
Is your HPS10 working correctly with other signals (e.g. internal calibration signal, battery voltage measuring, etc…) ?
Are you feeding the HPS10 from batteries or from a power supply. If you are feeding it from a power supply, does it have a common with the DUT?
