Hi, Can anyone explain if, and how, I can measure and compare two waveforms off of the same transformer 180 degrees out of phase, (eg one secondary tapping with reversedpolarity) using an HPS10 ?
I want to look at both waveforms to compare the difference but don’t know if this meter can do it - on a dual trace CRO I would simply attach a lead each to each input. I know how the HP10 can store a waveform, but I can’t seem to see on the screen the 180 difference e.g. the one out of phase starting at zero and going negative.
Can anyone help?
Yours in hope - Mike
