Hi, I have an HPS10, I’m wanting to view wavefrms of vehicle actuators and sensors, the unit doesn’t seem quite quick enough for the job, but anyhow, my main question is, can I set the trigger point horizontally any way?
If I want to see a fuel injector signal for example, the 12v feed is grounded for approx 2.5 ms then released, the voltage peaks at approx 60volts, then returns in a curve back to 12v feed until the next triggering event.
I want to see this event repeating on the screen, but I can only see the edge of the peak and after the event, when I really want to see the whole event, can this be done?
Can the trigger be moved across the sceen rather than just vertically at the side.?
