How to set up Cura?
[quote=“Bigskill”][quote]
The code in the second and third line moves the head to 10mm height then 15mm height.[/quote]
Yhank you, would you suggest to leave it like this?
I have another question, slicing with Curaengine the “tissue” of the object on the preview and then on the print, appeat very large, every line are spaced like 1 or 2 mm, and create a bad result on the print.
Is there any way to reduce this distance? I cant figure out.
The same object sliced with normal slicer appear normal with no space, but take longer to print.
Thank you in advance[/quote]
I Don’t know exactly what you mean. can you post a picture of that?
