I would like to be able to measure a voltage that swings between +15V and -15V using the analog input on the K8055. I need to proportionately reduce the voltage so that it will be in the 0 to +5V range.
What is the best method of doing this? An idea for a circuit would be much appreciated.
First I estimated rough values for the two resistors.
Then I simulated it using the MicroCap 8 simulation software.
In the simulation the input was a ramp wave going from -15V to +15V.
The resistor values are selected so that the output ramps from 0V to +5V.
It was quite easy to find a combination of standard resistor values.
This kind of simple circuits (up to 50 components) can be simulated with the free evaluation version of the MicroCap. microcapsoftware.com/index.shtm
