How to install the screenwiper intervalkit K2599?
After I made the K2599 kit, I don’t understand how I can install the kit. The user manual is not very clear to me.
I tested the kit, the led works how it should work when I connect the + and the - to 12V.
But what do I have to do with ABCDEF?
My car has a simple switch with only on and off. This switch has only three connected wires. One of them controls the endposition of the wiperblades. The other two are the + and -.
What should I do to install it correctly?
I hope someone can help me,
Greetings, Thijs
I’m sorry, but I’m sure you’ll understand that we are unable to supply wiring diagrams for any brand of car.
We suggest that you look-up the wiring diagram for your car or consult your distributor.
I hoped for a little bit more help, because I also said that the installation manual was not very clear to me. It doesn’t say which cables I have to connect with ABCDEF, so, can you explain what I have to do with these connectors?
I do understand that you cannot supply wiring diagrams for any car, but if you can anwer my question, that would be great.
Greetings,
Thijs
