I’m trying to print an object but the plastic seems not to lay down on the bed properly.
How can i set a higher temperature during the whole printing process?
Gerard
Gerard
Hello @glmvdschrieck
While printing go to menu.
Select Settings ==> Temperature ==> change the nozzle value: a value “in degrees”.
Or you can set in slicer software a higher temperature…
Best regards,
Velleman Support
Your answer came halas too slow.
I returned the Nano Printer to the seller because of mal functioning.
I will buy anaother 3D printer.
Greetings
Gerard
