I have a question concerning my results on PLA :
How can i improve this print ?
All the printed parts are like this
Due to Z Axis issue ?
https://drive.google.com/open?id=0B0SFtfe_nXKENFhjdlRVR1k1UjQ
https://drive.google.com/open?id=0B0SFtfe_nXKEUzRjaG1DR0tUekk
https://drive.google.com/open?id=0B0SFtfe_nXKEblBobXNWUFhIUUk
Thanks.
Seb
My config :
# generated by Slic3r 1.2.9 on Fri Oct 9 23:53:17 2015
avoid_crossing_perimeters = 0
bed_shape = 0x0,200x0,200x200,0x200
bed_temperature = 50
before_layer_gcode =
bottom_solid_layers = 3
bridge_acceleration = 0
bridge_fan_speed = 70
bridge_flow_ratio = 1
bridge_speed = 60
brim_width = 0
complete_objects = 0
cooling = 1
default_acceleration = 0
disable_fan_first_layers = 3
dont_support_bridges = 1
duplicate_distance = 6
end_gcode = M104 S0 ; turn off temperature\nG28 X0 ; home X axis\nM84 ; disable motors
external_fill_pattern = rectilinear
external_perimeter_extrusion_width = 0
external_perimeter_speed = 95%
external_perimeters_first = 0
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
extruder_offset = 0x0
extrusion_axis = E
extrusion_multiplier = 1
extrusion_width = 100%
fan_always_on = 0
fan_below_layer_time = 60
filament_colour = #FFFFFF
filament_diameter = 2.97
fill_angle = 45
fill_density = 25%
fill_pattern = honeycomb
first_layer_acceleration = 0
first_layer_bed_temperature = 50
first_layer_extrusion_width = 100%
first_layer_height = 130%
first_layer_speed = 85%
first_layer_temperature = 190
gap_fill_speed = 25
gcode_arcs = 0
gcode_comments = 0
gcode_flavor = reprap
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 150%
infill_first = 0
infill_only_where_needed = 0
infill_overlap = 15%
infill_speed = 35
interface_shells = 0
layer_gcode =
layer_height = 0.3
max_fan_speed = 60
max_print_speed = 60
max_volumetric_speed = 0
min_fan_speed = 35
min_print_speed = 30
min_skirt_length = 0
notes =
nozzle_diameter = 0.5
octoprint_apikey =
octoprint_host =
only_retract_when_crossing_perimeters = 1
ooze_prevention = 0
output_filename_format = [input_filename_base].gcode
overhangs = 1
perimeter_acceleration = 0
perimeter_extruder = 1
perimeter_extrusion_width = 180%
perimeter_speed = 30
perimeters = 4
post_process =
pressure_advance = 0
raft_layers = 0
resolution = 0
retract_before_travel = 2
retract_layer_change = 1
retract_length = 5
retract_length_toolchange = 10
retract_lift = 0
retract_restart_extra = 0.1
retract_restart_extra_toolchange = 0
retract_speed = 55
seam_position = random
skirt_distance = 6
skirt_height = 1
skirts = 2
slowdown_below_layer_time = 5
small_perimeter_speed = 30
solid_infill_below_area = 0
solid_infill_every_layers = 0
solid_infill_extruder = 1
solid_infill_extrusion_width = 0
solid_infill_speed = 30
spiral_vase = 0
standby_temperature_delta = -5
start_gcode = G28 ; home all axes\nG90 ; use absolute coordinates\nG21 ; set units to millimeters\nG92 E0\nM82 ; use absolute distances for extrusion\nM109 S190 ; wait for temperature to be reached\nG1 E10 F400 ; prime the nozzle
support_material = 0
support_material_angle = 0
support_material_contact_distance = 0.2
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0
support_material_interface_extruder = 1
support_material_interface_layers = 0
support_material_interface_spacing = 0
support_material_interface_speed = 100%
support_material_pattern = rectilinear
support_material_spacing = 2.5
support_material_speed = 25
support_material_threshold = 46
temperature = 190
thin_walls = 1
threads = 2
toolchange_gcode =
top_infill_extrusion_width = 0
top_solid_infill_speed = 30
top_solid_layers = 3
travel_speed = 200
use_firmware_retraction = 0
use_relative_e_distances = 0
use_volumetric_e = 0
vibration_limit = 0
wipe = 0
xy_size_compensation = 0
z_offset = 0
