How to eliminate borders?
hey there,
i was wondering how to eliminate those borders at the end of the print ? most of the models i print have a flat surfaces, but at the end of the print he keeps putting a border on it, even tho the border is not on the 3d model .
i have trying to look into the options but no luck so far hope annyone can help me on this one would be super :slight_smile:
grtz
Do the mean the line that is printed around the actual object right at the beginning of the print? This is called the ‘skirt’ and can be configured in Slicr settings under ‘skirt and brim’. I wouldn’t turn it off though, since it’s supposed to clean the nozzle and get an even stream of plastic before the first layer is printed.
edit: I just saw that you made marks in the picture. You mean the perimeter and those two streaks that go across the last layer?! I had sometimes problems when my model had errors. On the first picture I can see that there are intersecting triangles in your model. The red faces I mean. Get rid of these since these might be the reason for Slicr to make mistakes.
[quote=“Platinius”]Do the mean the line that is printed around the actual object right at the beginning of the print? This is called the ‘skirt’ and can be configured in Slicr settings under ‘skirt and brim’. I wouldn’t turn it off though, since it’s supposed to clean the nozzle and get an even stream of plastic before the first layer is printed.
edit: I just saw that you made marks in the picture. You mean the perimeter and those two streaks that go across the last layer?! I had sometimes problems when my model had errors. On the first picture I can see that there are intersecting triangles in your model. The red faces I mean. Get rid of these since these might be the reason for Slicr to make mistakes.[/quote]
great thx for the info :slight_smile: , gonna try that
