does anybody know how an existing object (*.stl file) can be cut in two halves, so that both halves can be printed with a big flat surface on the heatbed, without any support structures? Then I want to glue the halves together.
I don’t know about any automated software to do that. Personally, I use openscad for such tasks. Simply cut away one half and then the other. Of course you will also have to rotate one of the two halves.
Michael[/quote]
U can use netfabb. Basic version is FREE.
I don´t know about the Windows Program, but the Mac App is
very easy tp use, it´s nearly self explaining. Within half an hour
and i´ve understood the needed options of this program
It includes rudimental 3D design options eg cut, but no merge.
Also included is to build simple objects.
[quote=“Tectu”]Personally, I use openscad for such tasks. Simply cut away one half and then the other. Of course you will also have to rotate one of the two halves.
[/quote]
How do you import the *.stl file into OpenScad? I did see the export function for *.stl files, but I find no import function. OpenScad seems to accept only *.scad and *.csg files.
