How to control LED string lights using PC?
I would like to ask you for help with following project: I have LED christmas tree string lights that I want to control (functions: on/off, dimmer) using PC. This sting lights have 4 colours. Each colour is powered by 0 – 24V AC max 0.25 A.
I want to use: K8061 - EXTENDED USB INTERFACE BOARD, but which dimmer component I should use to control range 0 – 24V AC? Will K8064 - DC CONTROLLED DIMMER do the job?
Thanks,
Simon
The operating voltage of the K8064 is 230V AC (not 24V) and the control voltage is 0…5 or 0…10V DC
Could you recomend me other module that will work with K8061 and can operate 24V AC (with dimmer function) ?
Thanks,
Simon
No, not at this time.
What if I will drop dimmer functionality, then can I use K2634 to switch 12V - 24V AC ?
Thanks,
Simon
yes
