Hi all!
I use vm167 and one of the problems as follows:
Please, open and check my image
I use two functions:
- Read analog input (read voltage from potentiometer)
- I use potentiometer (VR=1K) and 5V on board (J6) as a source of supply.
- Analog signal is connected to AI1 pin
- Counter
- I use switch and 5V on board (J6) as reference source
- Digital signal (pulse) is connected to DI/O1 pin
My questions:
- In my model, Can the 5V on board enough supply for above 2 functions?
- In counter, Need I use reference sources?
- Limit on the length of the USB cable?
Thank in advance!
