Hello everyone,
I see that people connected the K8200 to cura 2.5 software.
I tryed it to but i can’t connect , what must i do?
Everything is standard so no firmware ugrade or something else.
Best regards,
Pascal.
Hello everyone,
Best regards,
Pascal.
I just watched the video on Cura 2.5
I got the impression that this version does not connect to the printer.
It looks like you have to save the Gcode to a SD card.
For that you will need the VM8201
http://www.vellemanusa.com/products/view/?id=526961
I am still downloading it.
I will let you know what I find.
Surely if Cura 2.5 will generate gcode this could be transferred to Repetier software to run from a computer. No need to use the VM device. Cura is built in to Repetier. I am using the latest iteration of Repetier but cannot find the version number of the Cura installed.
