Hello, I recently got the k8200 printer and I can not get it to connect on the repetier software. Whenever I try to connect the printer the message “The parameter is incorrect”.I have ensured to use all of the settings from the manual. I also have the custom version of the repetier software V0.95F.Could someone tell me how to install all the of the correct software and drivers so my pc connects to the printer?Thank you.
I’m not positive but I don’t think this printer will work with USB 3.0
Check to see if it’s plugged into USB 2.0 (Black connector)
