After I’ve finished the build I tried to run the first test, but the printer will not communicate with my linux-pc (tried on two machines ( the one with Ubuntu 13.04 - the other with Ubuntu 12.04 LTS)
So I connected it to an Win7 in a Virtual Box of one of may Ubuntu-PC’s and (after installing the FTDI-Driver) all went fine!
So why the hell the printer doesn’t communicate with my native Linux machines ?!?
The FTDI Driver pages states:
So there should be no additional driver installation necessary.
This could be confirmed by
dmesg:
dmesg | grep FTDI
[ 72.484431] usb 7-1: Manufacturer: FTDI
[ 72.527093] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 72.528307] ftdi_sio 7-1:1.0: FTDI USB Serial Device converter detected
[ 72.531558] usb 7-1: FTDI USB Serial Device converter now attached to ttyUSB0
and lsusb:
Bus 007 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
And in the repetier-software also there is the device /dev/ttyUSB0 available.
But connecting ends in a simple blink of a LED on the printers mainboard and than … nothing, The software stays in connected mode (no firmware announcement in the log) and the status bar says: “Connected - 5 orders waiting”.
So (again) what’s the hell is going on here, did I miss something basic and/or I’m stupid?
And please !!! don’t tell me “this printer is not developed to work with linux” !!!
the reason for the communication problem is not the Linux kernel, neither the device driver. The implementation of interface between mono and libc is limited to the standard baudrates.
If you use mono-2.10.18 there exists a patch which will help you to use the firmwares non standard baudrate, which is 250000.
To apply the patch you need to build Mono from the sources.
This will take some time and after finishing, you should have a full function repetierHost running at 250000 Baud.
Runs well on Debian-7 32 and 64Bit, Linux Mint, Ubuntu an other Debian based systems.
There is no other way, except upgrading to Mono3 using the standard firmware under Linux.
You could test your hardware, board cables etc. if you compile your customized firmware using 56700 Baud,
which should work in all circumstances. To do these, follow the instructions in the manual.
@AÄronR: tried it with both versions, the problem is the same
@filou: thank you very much for this detailed answer, I thought at all sorts of possible problemmakers but never ever about the underlaying mono, o.k. building a software from the sources is not really my favorite hobby but I will give it a try …
Fine to hear that it works on Fedora as well.
And now it’s by the people from Velleman to add this information to the docs, were at least the german pdf states “Linux : im Bau”
I have the k8200 printer and I want to install it in Ubuntu (10.4). I have Repetier v0.84, but I don’t know how to install the drivers and how to connect with the printer. Can someone help me and explain me all steps??
Just wanted to say, I was having exactly this isuue and the instructions above solved it nicely - I build an Ubuntu install on this laptop just to run as a K8200 server, so am very happy to have it working.
I have tried the method proposed by @filou. It worked well for my 32 bit Ubuntu 12.04 LTS. Unfortunately it was not possible to build mono from source with my other computer (64 bit Ubuntu 13.10). I am very grateful to @filou for the solution which made it possible to use my K8200 with it at least for one of my computers. Now I can only hope that the 250000 baudrate support will be built into future versions of mono from start so we do not need building a patched version from source. It is after all not a trivial, quick process. Perhaps Velleman can do some lobbying work for us…
$ ./autogen.sh --prefix=/usr
Running libtoolize...
libtoolize: putting auxiliary files in `.'.
libtoolize: copying file `./ltmain.sh'
libtoolize: putting macros in `.'.
libtoolize: copying file `./libtool.m4'
libtoolize: copying file `./ltoptions.m4'
libtoolize: copying file `./ltsugar.m4'
libtoolize: copying file `./ltversion.m4'
libtoolize: copying file `./lt~obsolete.m4'
libtoolize: Consider adding `AC_CONFIG_MACRO_DIR([m4])' to configure.in and
libtoolize: rerunning libtoolize, to keep the correct libtool macros in-tree.
Running aclocal -I . ...
aclocal: warning: autoconf input should be named 'configure.ac', not 'configure.in'
Running autoheader...
Running automake --gnu ...
automake: warning: autoconf input should be named 'configure.ac', not 'configure.in'
configure.in:9: warning: AM_INIT_AUTOMAKE: two- and three-arguments forms are deprecated. For more info, see:
configure.in:9: http://www.gnu.org/software/automake/manual/automake.html#Modernize-AM_005fINIT_005fAUTOMAKE-invocation
configure.in:578: warning: The 'AM_PROG_MKDIR_P' macro is deprecated, and its use is discouraged.
configure.in:578: You should use the Autoconf-provided 'AC_PROG_MKDIR_P' macro instead,
configure.in:578: and use '$(MKDIR_P)' instead of '$(mkdir_p)'in your Makefile.am files.
configure.in:2: installing './config.guess'
configure.in:2: installing './config.sub'
configure.in:9: installing './install-sh'
configure.in:9: installing './missing'
ikvm-native/Makefile.am:2: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
ikvm-native/Makefile.am: installing './depcomp'
mono/arch/Makefile.am:3: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/arch/alpha/Makefile.am:2: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/arch/amd64/Makefile.am:2: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/arch/arm/Makefile.am:2: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/arch/hppa/Makefile.am:2: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/arch/mips/Makefile.am:2: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/arch/ppc/Makefile.am:3: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/arch/s390/Makefile.am:2: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/arch/s390x/Makefile.am:2: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/arch/sparc/Makefile.am:2: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/arch/x86/Makefile.am:3: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/dis/Makefile.am:1: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/interpreter/Makefile.am:1: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/io-layer/Makefile.am:4: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/metadata/Makefile.am:63: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/monograph/Makefile.am:14: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/profiler/Makefile.am:7: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/tests/Makefile.am:912: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
mono/utils/Makefile.am:3: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
runtime/Makefile.am:2: error: support for Cygnus-style trees has been removed
support/Makefile.am:10: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
tools/sgen/Makefile.am:3: warning: 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
**Error**: automake failed.
