For a project I need a simple chronometer that can be used on a big display.
*I need 2 (maybe 3) inputs; start, stop and reset.
*I need a big display, clearly visible for outside use. (the bigger, the better)
*there is only a small budget available
I am thinking about two options;
1.: I can use a laptop with an external large monitor where i can run an apliction as ex. online-stopwatch. The problem is the interface. I need 3 external inputs…
- : I can use a timer module. The problem is; how can I display my clock? Can i Start,stop, and reset the module from an external signal (remote or cable).
