Hi guys, Im new to electronic kits, in fact this is only my second one. I bought this one and my first on the same day at the same time. I built the other one first because it was just a tiny fm transmitter, perfect for a first project. I chose the k8006 because it was in the marked down bin at my local electronics store and i got both kits plus an assortment of other junk for under $20. Once I got home I saw that the kit was rated 5, advanced. I’ve done a little soldering before and figured this would be good practice and if I screwed it up I wouldn’t be out much. Well, I did a great job, better than anyone would have guessed. The only part I didn’t fully understand in the obstructions was the part about adding an extra layer of solder on all ‘thinned’ areas. I took that to mean the long lengths of exposed tracks that run along the top where the loads are attached. Ypu cam see in the pic where i added the extra solder, is this where it went? I’m fairly confident that it works but I’m not 100% sure how to test it. The part that confuses me is whether or not i need a module plugged in. Is there a way to teat the circuit if I have no module? Thanks for the help and I look forward to building lots of stuff, great fun! Below are pics of my completed project. I apologize for the quality of the pics but phone cameras aren’t exactly the best thing to use for detail.
Ugh, im having trouble getting to my pics on this iPad, I will post the pics separate from my computer shortly.
